Old Sep 15, 2008 | 07:09 PM
  #49 (permalink)
P-DuBBs's Avatar
P-DuBBs
Talking Re: Oil change made easy
Originally Posted by MikeR
Mine didnt seat all the way when I put in the first time. I pushed it on a little harder and it popped all the way in. I dont know if you have the same thing or not. If you have the cap screwed all the way down to the 25Nm(?) it should be seated. Did you pull it back out and check it? I would think it might be squashed a little if you didnt have it seated all the way. Or it just might have seated when you tightened down the cap.
MikeR
Yup, same thing happened to me. It didnt go in all the way the first time but i was able to move it in more after a better push. Yes i did pull it back out and it didnt look damaged to me. I used an oil filter wrench to tighten the cap. (BTW I'm using the same Mann filter I believe you used). Thanks Mike. I'm thinking it must've seated properly then. Makes me feel better.
