Originally Posted by drunkiq
...The problem is that the SLK32 "upgrades include a high-flow low-back-pressure exhaust system" which means we will a ton of torque on the bottom end. It looks like our only choices for a catback system is going to be the Eisenhaus or Borla catback.
high flow = low back pressure. Isn't that what Eisenhaus or Borla does? All low restriction exhaust system will give you more hp at the high end with some loss of torque at the low end. The trick is to balance the two effects...Unless you can come up with a variable baffle systemmmI think the Maxima had something like that...
IMO I don't think you'll lose a TON of torque...
