Old Sep 16, 2008 | 06:09 AM
Bulldogger's Avatar
Bulldogger
Default Re: Has anyone had there 185mm Pulley Fail?
I thought you had the water pump pulley go at the same time so you were unsure which happened first, also didn't you take the crank pulley apart before the problem?? not implying any thing just don't remember anyone having crank pulley problems. I do know that when I got mine the center hub was not tight with the allen keys and could have caused a serious problem if I didn't check it first before install.
