Re: Has anyone had there 185mm Pulley Fail?
When you guys see the updated water pump pulley you will never worry about it failing again.
The most important thing about the 185-181 crank pulley is check those hex bolts and use red loc-tite! If you hear something that sounds like rod knock and then see your pulley wobbling rest assured the bolts have lossened and sheared off.
Waldig is the only person i know who sheared the keway off the crank. I dont understand how this could have happened. I have installed/uninstalled my 185 pulley about 15 times now, no issues yet with the keyway. As far as the keyway slot in the 185 its the same as the stock one...just a cut out grove.
