Old Sep 16, 2008 | 08:40 AM
Opticon's Avatar
Opticon
Default Re: Throwing my 1-second power loss problem at you guys...
Did anyone use an OBD scanner to check for fault codes? It could point out your problem.
Also, don't forget the throttle control circuit. With all of the variable between the pedal and the throttle blade, I'm suprised we don't have MORE unexplained problems.
The 1 second power loss sounds like what happens when the Traction Control engadges. You don't get the traction control light flashing in your face when it happens, do you?
