Old Sep 16, 2008 | 12:12 PM
240M3SRT's Avatar
240M3SRT
Default Re: Has anyone had there 185mm Pulley Fail?
Originally Posted by waldig
While running I got BAS/ESP codes due to overheating and the power loss ( sudden nose dive) caused it to snap back and forth enough to do it in. Not something I wanna deal with again. THere is too many failures going on and someone will get into a real pickle if they are in traffic at the wrong time.
Woody
I respect the heck out of your inginuity and what not, but its hard for me to grasp your train of though on this one.
I believe BAS/ESP has to do with the brakes. Overheating also seems unrelated to an oversized crank pulley. If the car nose diving under deceleration is going to destroy a crank pulley by causing it to snap back and forth then it wasnt on tight in the first place.
IIRC, didnt you have to modify your crank pulley to get it to sit flush on the crank? Wondering if this has anything to do with the fact that your the only one with the keyway problem. Im not blaming, simply wondering.
I do agree there are more problems then what should be going on, but the causes are being remedied as they appear. Its got the gears in my head turning(Waldig close).
