Old Sep 16, 2008 | 03:41 PM
Bulldogger's Avatar
Bulldogger
Default Re: Has anyone had there 185mm Pulley Fail?
The 178 ASP pulley had some issues also with the rubber dampener coming loose and vibrating the motor causing the front crank seals to leak. The LET178/181/185 pulleys were made better then ASP or Renntech which basically welded a larger outer ring on a factory stock one. The problem was in the water pump pulley, which was recalled. It sucks that there was a problem but only walding sustained damage that I remember.
