Old Sep 16, 2008 | 04:09 PM
FTroopChief's Avatar
FTroopChief
Default Re: Vibration between 70-80 mph
Balancing is usually the culprit, however, have your tires been matched to your wheels? Before spin balancing especially with new tires and/or wheels, they should be matched to each other to assure any high or low spot or out of round is compensated for. A new tire generally has a yellow piece of tape indicating a reference spot and wheels should also have a mark. If the tires and wheels don't match, there is about a 3 to 4 inch window the tire can be moved on the wheel. Then balancing should be done. I prefer a hunter machine, but an old pro can do a PDG job on a static balancer.
FROM TIRE RACK: http://www.tirerack.com/tires/tirete....jsp?techid=17
Tire and wheel manufacturers continually develop new manufacturing methods to enhance the uniformity of their products because radial runout, lateral runout, force variation and imbalance can affect a vehicle's ride quality.
Match mounting tires on wheels is a process where a tire's installed position on the wheel is specifically selected to help minimize the final combination's force variation and/or imbalance. One match mounting procedure aligns the tire's measured high point of radial force variation with the measured low point of the wheel's radial runout. The other simply aligns the tire's lightest spot with the wheel's heaviest spot.
Original Equipment (OE) tire suppliers are required to mark the tire's "high point" while OE wheel manufacturers mark the wheel's "low point." This helps the vehicle manufacturer match mount combinations that maximize new car ride quality while reducing the amount of balancing weight.
Today, many vehicle manufacturers specify the use of a temporary tag applied to tires and wheels that are removed before the vehicle is put into service. Unfortunately, this means that there are no permanent marks to reference later.
There was a time when the valve stem hole on standard wheels indicated the optimum place to which the tire should be match mounted. However, with the advent of styled, steel wheels and aluminum alloy wheels, the stem position evolved into an aesthetic issue rather than being a uniformity indicator. Add to this the probability of wheels retaining their original runout after thousands of miles of use and you can understand that simply mounting the tire so the colored dot is at the valve stem is no longer required practice.
We have found that the only way to accurately match mount replacement tires on used original or new aftermarket wheels is to use Hunter tire balancers which have the ability to measure wheel runout and tire force variations under load before the tire and wheel are installed on the vehicle. Using these machines, a colored dot might be positioned anywhere on the wheel relative to each wheel's runout measurement. In the end, the markers have little, if any, relevance when replacement tires are installed.
Hope this helps Check your WINTER tire pressures too....
John P
