Originally Posted by andrew
3.)...Twist screw driver against pad and rotor to move piston.
11.)...Reinstall sensor wire. (only on driver's side)
14.)...Torque lugs to 78 ft lbs.
I would like to add:
3. I recommend caliper retracting tool (<$10) or C clamp instead
11. The brake pad wear sensor is on both front brakes
14. Book says 81 ft lbs.,
10. 7 mm Caliper retaining (allen) bolt torque is 41 ft lbs and should be coated with silicone grease or caliper grease.
