Old Sep 19, 2008 | 03:45 AM
Stogey's Avatar
Stogey
Default Re: Weird noise from engine at idle
Geez Mouse ! Sounds like a belt squealing !!!
Remove your accessories drive belt and start it up again to better isolate the noise. It will be fine to run this way for a few minutes.
You may need to clear a few fault codes after re-installing the drive belt. Worst case....idler, water pump, SC, pulley bearing.
Keep us posted !
