Old Sep 21, 2008 | 08:48 AM
amx1397
Default Re: Rear end pulling to the left.
take a tape and measure from center to center of front to rear on both sides they should be the same ,,if need place tape in same place on the on each side if you are doing this alone,, also jack up the rear only a few inches,, one at a time and see if you can move the wheel up and down and is it sloppy and a;lso back and forth. do the same to the front up and down.
