Old Sep 21, 2008 | 07:28 PM
maxcichon's Avatar
maxcichon
Default Re: Under-hood Temperature Profile
Originally Posted by jbomar
The thermocouples are not attached directly to any plastic surfaces. They are offset from these surfaces by 1/2 to 1 inch in an attempt to more closely monitor actual air temps as opposed to "component" temps. Once again, with a 3Hz sample rate, you can see in the attached graph a great deal of "saw tooth" in the data; if they were directly attached, I agree you would see much more smooth curves.
I'm not just blowing hot air either!....I design and install industrial ovens bigger than most suburban homes!
Ok, one last question:
On the 2 TC's on the intake tubes, how did you get the tips of the TC's inside the tubes and into the airflow? It almost looks on the passenger side as if the tip of the TC is sticking OUT/AWAY from the plastic tube.
