Re: Xenon HID $75.98 Shipped!
Alright....I ran into a problem installing these HIDs. First I did everything correctly on the left side and the HID did power on. But then by accident, as I needed to do something else, I unplugged the wire harness from the original bulb line and then when I reinstalled the harness wires into the original bulb lines, I must have reversed the negative and positve lines....I suppose the capacitor on the wire harness burned out (not 100% sure yet)....anyways my bigger problem is that when I went to reinstall the old halogen bulb the headlights wouldnt light up...only on that affected side. Bulb is good. Highbeams work. Is there a fuse for the left low beam headlights? Cant find the fuse in the fuse box. What else can be wrong?
