Bullfrog... My mechanic found that rough idle was being caused by loose PCV hose that is attached to the throttle body... Said that some of the cars that were delivered didn't even have the hose attached... If you are familiar with the engine, remove your airbox and the airflow meter... The hose is just below the airflow meter... re-insert the PCV hose or tighten its connection... This fixed my problem finally...
