Old Sep 27, 2008 | 10:20 PM
NeverEnough's Avatar
NeverEnough
Default Re: Belt Strap Wrench for Supercharger Pulley Upgrade ?
Originally Posted by kldiet
The standard 12mm bolt should be torqued to ~14 ft/lbs (20nm). The Blue strap will work great to do this job, unless someone else has used an impact wrench to over torque to 30 lb/ft.
I apparently had unique circumstances... There is NO WAY that thing was only originally tighten to 14 ft/lbs. That's just my luck I guess. You don't break a bolt and a strap wrench removing a bolt with 14 ft lbs. Murphy HAS ALWAYS hated me... I hope no one else has this problem.
