Originally Posted by AlG
The drain plug is on the passenger side of the oil pan. It will leak if the metal O-ring that goes on the plug is not put back on. You'd have to take the skid plate off to check but it's easy...four 8mm bolts. Good luck.
Thanks AIG! It all makes sense! with the exception of the leak stopping. I'll check again. Didn't the government just bail you out (lame joke)
