Re: Clear front markers...
Did you guys notice that the front and rear markers are exactly the same shape? RR is the same as LF and LR is the same as RF. The colored area is the same, but the bulb location in the housing is moved forward. With a very small amount of modification to the rear marker area, the clear markers should fit. Then finding red bulbs would be the next step. Just something to think about, should you have an extra set laying around.
James
It's been done already. Somebody had an alabaster coupe with clear markers on all 4 corners at Carlisle in 2007. You're correct, they were modified to fit.
