Old Sep 30, 2008 | 03:35 PM
ppro's Avatar
ppro
Default Re: 80 mph rear end noise and the dealer
Originally Posted by bogieman
Took him for a ride, and when the noise starts, he turns up the fan and turns on the radio. He says Chrysler has a noise limit and if you can't hear the noise with the radio on and the fan on it is not loud enough.
Man, my B.S. detector needle just pegged all the way on "BULL" and bent!
You, sir, are being lied to.
They do have to check backlash and preload etc. to diagnose the problem but he's right - if he takes it apart, it's pretty unlikely it will get better by plain adjustment. It will stay the same or get worse. The only way to "cure" it is to replace the ring, pinion, and set it up properly. You've got a better chance of a Jeep mechanic doing it right than a car shop that probably doesn't do them very often.
Go find another dealer - that one is getting ready to bend you over and start shoveling more B.S., while they help themselves to your wallet.
