Re: do YOU know the boost...
Originally Posted by amx1397
I have been told 12lbs, and also told 141/2 lbs and would like to know what the book says and if any one has a stock car with boost gauge what does it read? l
stock with gauge in car = installed gauge today 10 at w.o.t.
stock =Stock, factory pulley I got a touch over 14 PSIG
next would be with a SC pulley? = 17-18lbs with the Code 3 Pulley
next would be with the 178 pulley =17.5-lbs boost gauge running the 178.
next would be with the 181 pulley = got an ODB reading of 20.3psi at WOT
and last would be with 185 pulley boost: 16.9psi peak and or 185mm Pulley @ 6,100 RPM sea level = 21-23 Lb.
what does the renntech equal = ((16- 17 as well with the renntech pulley))
