Re: do YOU know the boost...
here is what we have if you can make heads or tails of it. right now my car is stock wot i got 10) at sea level, now i will boost leak check and add a pulley.
I have been told 12lbs, and also told 14.5 lbs and would like to know what the book says and if any one has a stock car with boost gauge what does it read? lmine reads 10 at wot
stock with gauge in car = installed gauge today 10 at w.o.t.
stock =Stock, factory pulley I got a touch over 14 PSIG
next would be code 3 SC pulley? = 17-18 lbs with the Code 3 Pulley
next would be with the 178 pulley =17.5-lbs boost gauge running the 178.
next would be with the 181 pulley = got an ODB reading of 20.3psi at WOT
and last would be with 185 pulley boost: 16.9psi peak from one member and 185mm Pulley @ 6,100 RPM sea level = 21-23 Lb. from another
what does the renntech equal = ((16- 17 as well with the renntech pulley))
