Old Oct 2, 2008 | 03:27 PM
drivethruecp's Avatar
drivethruecp
Default Best location for Fog & High Beam Ballasts (4)?
I just installed my McCulloch 6000K HIDs for both my low beams and my fogs. I am back and forth as to where to mount the ballasts since I have 4 total, 2 to each side. The fogs are fished through the nickel-sized hole between the engine bay and the space where the fogs sit. There is a blank mounting screw on the drivers side fender and can hook up to the cable clamp screw on the passengers side. But originally I wanted to hide them fully. I had mounted them under the headlight housing (upside down) with 3M outdoor dbl stick tape. I just don't really trust them under there and will only be a matter of time before they fall. The flat metal under the headlight housing doesn't have quite enough room for even one to lay flat. Another option is to stack them on top of each other..
Where did everyone else mount there's? I really want to stress a clean/stock look.
