Old Oct 7, 2008 | 06:31 AM
mrphotoman's Avatar
mrphotoman
Default Re: Went to the DYNO-DYNO-DYNO-DYNO-DYNO-DYNO
You can not just look at peak numbers. I charted it for you, as you can see the code3 pulley gave you big gains across the rpm range for both torque and hp. This is not exact since the charts did not plot the same exact rpms but it should be very accurate:
