Old Oct 7, 2008 | 07:07 AM
MikeR's Avatar
MikeR
Default Re: stripped star bolt - code3 pulley, help!
I think I read on another thread here that the E11 bolt is held in place by a 12mm(?) lock nut and that you can use a 12mm socket on that instead of the E11. Using the lock nut may cause the lock nut to loosen up. But since you need to replace the E11 anyway....no problem. Good luck.
MikeR
