Old Oct 7, 2008 | 12:34 PM
nox1s's Avatar
nox1s
Default Re: HID Installation guide, with pictures. [Low Beams Only]
Now for the passenger side, I used a self tapping screw and put the harness right by the overflow tank. IMG_0035.jpg
There is also a spot down below by the engine that there is a hole already there, you can just put a screw in there and mount the harness there.. Picture is really blurry but the black dots are the holes.
For the passenger side, you have to do the same thing as the driver side, but you have 90% less room. This is where small hands come in play, otherwise your hands will feel like they've been through meat grinders. Some people take the whole headlight assembly out, I DO NOT recommend doing that. Some people also take the overflow tank out to give them a little bit more room.
To be honest there is no real easy way to do the passenger side, it is a royal pain in the ***, but very doable. You can move the hose by unclipping it and moving it out of the way, this helps a tad. IMG_0034.jpg
That's it, if there's anything else i've missed / need help with, please let me know.
