Old Oct 7, 2008 | 07:24 PM
enzio55's Avatar
enzio55
Default Re: Bad Battery? Car Cranks Fine, But Stalls Under Throttle
Did anyone bother to check fuel pressure...??? no codes will show up on a faulty pump..when the car is about to stall a battery light is normal ...as for a cracked battery..that can't be good if battery voltage is down your going to have all sorts or driveabilty problems, also under the battery tray is a major wire harness.. if you remove the battery your going see some corrosion on the wiring
