Old Oct 8, 2008 | 06:52 AM
outtatime's Avatar
outtatime
Default Re: stripped star bolt - code3 pulley, help!
Originally Posted by MikeR
I think I read on another thread here that the E11 bolt is held in place by a 12mm(?) lock nut and that you can use a 12mm socket on that instead of the E11. Using the lock nut may cause the lock nut to loosen up. But since you need to replace the E11 anyway....no problem. Good luck.
MikeR
i gotta look at that thing again sober, but i remember a lock nut on there. i tried to use that to release the tension, but mine was on there so light that the belt didn't move at all. i think it was a 15mm..... i'll have to double check again though.
