Old Oct 10, 2008 | 07:57 AM
GB'sXFire's Avatar
GB'sXFire
Default Auto Stick questions
I dream of the strangest things. I dreamed last nite I had an auto-stick and it didn't shift like I thought. Anyway, for you all with the auto tranny, when you use the manual mode, and are like in second gear, can you bounce off the rev limiter, or does it shift up to the next gear? Also, if going hard into a turn, and are slowing down, can you brake and tap the shift lever down like maybe two gears and use engine braking, like in 4th gear and tap twice to go to second, will the tranny go right to second, or does it go from 4th, 3rd, then 2nd? When tapping the gear selector up or down, are the shifts instant? Ok, I think that was all my questions from my dream last nite! Thanks.
