Old Oct 11, 2008 | 12:52 PM
outtatime's Avatar
outtatime
Default Re: stripped star bolt - code3 pulley, help!
Originally Posted by waldig
Fan removal is 90 seconds )sober time(.
Find and release fan connector, goes down off the shroud.
Release fan connector halves and separate.
Find and pull up and off the two fan clips on top L and R
Remove from plastic clip the small hose and hold it out of the
way as you lift the whole fan and housing as one piece
straight up. Check manual on line in forum
Reverse for install. Water heater hose on driver side will flex out of the way with some care, I have done this several dozens of times while doing testing and changes on cooling.
Woody without a BUZZZZZ
Thanks for the advice! I'll try it ASAP, and I'll let you guys know how it goes!
