Old Oct 12, 2008 | 03:26 PM
Eleventeen's Avatar
Eleventeen
Default Re: New and improved Heat exchanger installed, TAAA DAAA
Originally Posted by ohnoesaz
Its in front of the lower radiator, where very little air goes (Read Woody's extensive posts on this). The stock H/E should be adequate if moved to in front of the upper part of the radiator, behind the upper grill.
Woody is all about cooling through and fabbed up a much better H/E, but for "common" people like me just improving the stock setup is good enough, and the stock H/E will work fine if moved upwards.
I think the stock H/E moved upwards will give the same performance as the LET H/E mounted in the stock lower location, or at least in the same range....
Can't speak for the SRT6, but where the stock H/E is located on the C32, it gets plenty of air and still sucks. Placement definitely makes a difference, but you also have to consider coolant flow through the H/E which is much better on the after-market units.
