Old Oct 13, 2008 | 05:37 PM
07bluezx14's Avatar
07bluezx14
Default Re: lining up headlights
how far out should the low beams illuminate. my drivers side low beam ends 16ft out, the other goes out a little farther. If I use the top adjustment, it moves all of the bulbs, how do you adjust the low beam only? High beams seem ok. I plan on a full hid setup, does it sound like the bulb isn't seated correctly? also one of my fog lights, has the silver cap, the other is just a regular bulb(no cap), from what I have read it would seem that the passenger side(no cap) has had a new assembly installed. would that seem correct? thanks chris.
any heads up on changing out all of the bulbs.
