Re: Question on check engine light and multi-function switch.
What you want to know from the Crossfire Service Manual. It's part of the Windshield Wiper / Turn signal switch / Headlamp high beam etc..switch assembly.
MULTI-FUNCTION SWITCH
DESCRIPTION
The multifunction switch and control circuitry (3) is concealed
below the steering column shrouds and will operate when the
ignition switch is turned to the ACC or ON/RUN positions.
Fuse 32 in the underhood accessory fuse block protect the circuitry
of the wiper system and the vehicle.
REMOVAL
WARNING: ON VEHICLES EQUIPPED WITH AIRBAGS, DISABLE
THE SUPPLEMENTAL RESTRAINT SYSTEM
BEFORE ATTEMPTING ANY STEERING WHEEL, STEERING
COLUMN, DRIVER AIRBAG, PASSENGER AIRBAG,
FRONT IMPACT SENSOR, SIDE IMPACT SENSOR, SIDE
CURTAIN AIRBAG, OR INSTRUMENT PANEL COMPONENT
DIAGNOSIS OR SERVICE. DISCONNECT AND ISOLATE
THE BATTERY NEGATIVE (GROUND) CABLE, THEN WAIT
TWO MINUTES FOR THE SYSTEM CAPACITOR TO DISCHARGE
BEFORE PERFORMING FURTHER DIAGNOSIS
OR SERVICE. THIS IS THE ONLY SURE WAY TO DISABLE
THE SUPPLEMENTAL RESTRAINT SYSTEM. FAILURE TO
TAKE THE PROPER PRECAUTIONS COULD RESULT IN
ACCIDENTAL AIRBAG DEPLOYMENT AND POSSIBLE
PERSONAL INJURY.
1. Disconnect the negative battery cable.
2. Remove the steering wheel. Refer to Page 19-25.
3. Remove the clockspring. Refer to Page 8O-94.
4. Remove the lower instrument panel. Refer to Page 23-149.
5. Remove the screw (1) attaching the speed control switch to
the multifunction switch.
6. Remove the bracket below the speed control switch.
7. Remove the screws (2) attaching the multifunction switch to
the steering column.
8. Disconnect the multifunction switch harness connectors.
9. Remove the wire harness from the steering column.
10. Remove the multifunction switch from the steering column.
I hope this helps.
