Old Oct 14, 2008 | 05:48 PM
mprince's Avatar
mprince
Default Re: Question on check engine light and multi-function switch.
Originally Posted by Stogey
I would have the dealer give you a lil bit better explanation and possibly show the part to you ! The only multifunction relay I can think of is the Relay Control Module which is no where near 350 bucks to buy. More info.....please !
So, here's what they told me. Note that this was the service manager, not the technician. The technician had left for the day when I picked the car up.
Diagnostic code is Stored Code 2023. I couldn't find that code anywhere. The description is Secondary Air Injector Relay Circuit Signal Error, which seems to relate to the P0410 error mentioned in an above post. The stated fix is to replace the Air Injector Module. I don't know what part this is to look it up and see how much it should cost, and whether it's a part that can be replaced fairly easily.
TIA for your help!
