Re: How in the F do you change the headlight bulb? Broken thumb edition.
Disconnect the the plug from the bulb first then push the bottom of clip in a little and move it to the left or right depends which light it is. Then when you unclip it you can lift it up out of the way to remove the bulb. It might be easier if you have a long curved pair of needle nose pliers. It makes it a lot easier than trying to do it with your fingers.
