Re: superseaded part numbers
Thank you Sowardcustoms, for confirming I was correct, now I just got to get one to replace the one that did not come with the deflector, I know there is one in Sherwood depot an original I think the only one left, so I will try to get it and if not I will try the Benz people, for the Benz replacement, and if not I will swap out just the rubber insert from my old one I saved also, but you have to bend out the tabs a bit to get it in place so eventually it probally will break due to bending back and forth, again guy's thanks so much for all the help. Since the new version has no mountings for the deflector.
