Old Oct 18, 2008 | 08:43 AM
Eleventeen's Avatar
Eleventeen
Default Re: Installed Meziere IC pump.
Originally Posted by jturkel
i was searching around and couldnt find which is a better pump to have: the Meziere IC pump or the CM30? Does one pump more than the other? Is one an easier install on the C32?
Johnson flows 6.9 gpm and is pretty much a direct fit. Meziere flows 20 gpm and will need a custom bracket and hose routing. Johnson is probably good for most applications, but I went a little nuts.
B.T.W. you can hear this thing running from inside the car.
