Old Oct 18, 2008 | 03:34 PM
Eleventeen's Avatar
Eleventeen
Default Re: Installed Meziere IC pump.
Originally Posted by waldig
You mentioned that the spike in IAT is in your mind due to possible oil on the I/C. Short of pulling it (NOW) do you have an idea of what we could fog or spray into the inlet while running to help rinse that too. I have become so involved with that issue that Iam assisting the development of a low restriction separator canister to address this issue, Thanks.
W DY
I thought of possibly spraying something in there before, but then realized it probably wouldn't work well (or even be a good idea due to it having to go through the supercharger). Some old-school carb cleaner is what initially came to mind. If the intercooler is off, then I imagine some engine degreaser or maybe even Simple Green would work. Unfortunately, I will not be trying any of this as my intercooler is leaking (not sure if it has anything to do with this badass pump or not ). I have put my name on the list for one of the first Code3/Spearco intercooler cores.
Honestly, if your car has some miles on it, I would highly recommend removing and cleaning the intercooler core, after seeing how much oil is inside my intake manifolds. My car has a little over 65,000 miles B.T.W.
God speed on the oil separator mod. I will be doing this upon installation of the new core. I was thinking of using something like this:
Back to Jegs ...
http://www.jegs.com/p/JEGS/760016/10002/-1
