Old Oct 18, 2008 | 03:38 PM
Mimi05SRT6's Avatar
Mimi05SRT6
Default Went to the Dyno today...
Well, I finally got a full dyno with all the info to send to Jerry at LET. According to the spreadsheet, temp was 86 degrees. Dynoed in 4th gear to 150 mph. The mods are deleted rear cats, Code-3 pulley, Jerry-LET Tune, and Intake. Surprisingly, the air fuel basically stayed around 12 through out the entire rev range which you can see in the photo below. 308.86 whp, 310.61 wtq. Seems to be low numbers for the mods I have, what do you guys think it should be at? I wish there was a way for them to dyno the car at 3000 rpms without having it downshifting to the lower gear. Could only start at 4000 rpms.
The most amazing thing that happened at this dyno day is a Viper GTS showed up with a GT55 turbo and put down an astonishing 1290 whp! You have to close your ears and also the wastegate underneath the car sent a blast of wind everywhere! It was the most amazing thing I've ever seen. Of course you had to leave the room right after because of the fumes!
