http://www.needswings.com/ProductDet...?productID=621
ok, we have enough here in stock to cover all the intake manifolds going out and have extra's for those that want their factory manifolds to properly seal over stock boost.
those with phenolic spacers.... your leaking and loosing power because of it. phenolic sheets that spacers are cut from are not flat like a decked surface and the oem gasket cannot compensate even at stock boost.
Will this fix the problem using your gaskets with the phenolic spacers?
