Old Oct 21, 2008 | 03:56 PM
Beaner's Avatar
Beaner
Default Re: A new cupholder replacement question for you lol
Originally Posted by Fenwick223
I did the same thing as you did. After my cupholder broke, I did not want to take the entire console out so I used a sharp pair of wire cutters and cut away the remaining parts. When I tried to insert the new box, it would not go in. I found out the "walls" of the cupholder also have to be removed. I would recommend that you use multiple layers of masking tape to protect the console, especially around the opening. Then start cutting away. It takes patience, you have to be careful, and it will take some time but it's better than removing the console. Eventually you will get it all out and the box will slide right in (and I think it goes in B).
Much as some like the cupholder, the box is MUCH more useful IMHO. Good luck!
What he said!
