Old Oct 21, 2008 | 04:02 PM
Fritzauf's Avatar
Fritzauf
Default Re: camber kit question also 20 inch 19 inch combo
If you're having a problem with uneven tire wear due to negative camber you will most likely need to install the Camber Adjusting Bolt kit. Check your shocks also. Your Chrysler dealer can get the proper Camber Bolt kit reasonably priced and install it also.
