Old Oct 22, 2008 | 01:43 PM
tighed1's Avatar
tighed1
Default Re: Rough install = Code 3 pulley squeeks when engaging when cold
Hey Woody!
I don't think it's an issue of "wobbly". My pulley mounted perfectly straight the problem was the gap between the supercharger "flywheel" and the plate on the pulley that engages the SC flywheel. Just looked at my pulley and the uneven gap that I had has worked its way into alignment where the gap is nearly even now. I attribute the initial uneven gap to the tabs that connect (riveted) to the pulley and the pulley's moveable plate. Over time it seem they will settle into proper alignment. Initially I used all of the shims supplied with the c3p I have since gone to just the original two that were on my stock pulley.
