Old Oct 25, 2008 | 07:59 AM
mrphotoman's Avatar
mrphotoman
Default Re: Code3 + ASP 1/4 mile results... not so much.
you need the supporting mods to go with that.
i feel that without alcohol injection, anything higher than 17psi is a waste of time.
what is your a/f ratio and did you update your tune for the higher boost?
your mph in the 1/8 and the 1/4 are really low. it is pulling a lot of timing to compensate for the heat the boost is making.
