New injectors installed now I have rough idle
Oct 25, 2008 | 01:31 PM
permalink
TVT_DESIGN
Guest
n/a
Re: New injectors installed now I have rough idle
A loose plug will not cause a CEL, either will an unproperly seated injector.
You should have no more then a 16th or so of an inch showing at the bottom. If using the retaining clip use the top slot.
