Old Oct 26, 2008 | 12:05 PM
TVT_DESIGN
Guest
Posts: n/a
Default Re: New injectors installed now I have rough idle
Originally Posted by danimal
After seeing Anthony's post yesterday, I re-did mine this morning. I was seeing the same things you are. Pull the injectors back out of the fuel rail about 1/8th of an inch and you will see a notch. The clips slide in perfectly and the plugs "snap" right into place with no problem at all. You also will not see the o-ring on the bottom after reinstalling. It took about 2/3 less time just knowing that little bit of information.
It's a shame there wasn't info provided that would have made this a simple install for the average DIYer. It isn't hard to do.....when you have all the information needed. I do have to say that the wiring harness cover is probably the worst part of the whole darn thing....what a pain in the ****.
Sorry, I will work on getting some detailed info for this install. I take for granted the little steps.
