Old Oct 28, 2008 | 12:14 PM
  #51 (permalink)
tylerxfire's Avatar
tylerxfire
Default Re: bragging rights!
very aware. I spoke with him a while ago and he said he only uses it at the track which is prolly good for more reasons than one, he is using a chip that advances timing also, so. . take that how you want but anyone who knows about nitrous knows not to advance timing but to retard it for spray. Im sure if someone only sprayed 75 shot and could retard timing while spraying 1.5 to 2 degrees they would be fine if used sparingly. but after all it is still only gonna run low 14's to high 13's with many other bolt on's so is it really worth it. why not just get a srt-6 if you are set on the crossfire. basically you take a stock crossfire srapy a 75 shot, its good for low to mid 14's maybe with a great driver.
i stated before when i had needswings intake, magnaflow cat-back, and 75 shot, i was dead nuts with my buddies 97 bolt on m3. his best time ever is a 14.2, he runs consistent 14.4-14.5 at the track. just really don't see it being worth it. especially when the motor goes because you are spraying all the time to keep up with low 14 second cars and you could have a srt-6 that goes low 13's out of the box. and waayy more potential.
