I am so pissed...
Oct 29, 2008 | 02:17 PM
25
permalink
MikeR
Jan 2008
5,180
North Plains, OR
Re: I am so pissed...
Randy, thanks very much for your efforts. I am pretty sure that I can make an aluminum one. That will fix mine but everyone else will be screwed if we dont find out what the part number is and where to get it. hmmmmm... maybe I could make a LOT of money
And the good news is, IT's ALIVE!!! I just finished putting everything back together on the Aero and it is running fine. I did have a starting up problem at first. Cranks away and no fire. DTC shows P0335...da@%$ that crank position sensor. Tried reseating the connectorl...no help..swapped the sensor...no help...tweeked the pins on the connector and the sensor...no go. Wait, I thought I saw something odd on the frame data about the voltage. Get out battery charger and set for 200amps crank. Key on...IGNITION! We have lift off... I let the car warm up some and shut it off and tried again. No fire. Battery charger again and ignition again. This time I take it for a little drive and blow out the cobwebs and get it all warmed up. Shut it down at home and it fires right back up. I am thinking that my battery is starting to act up and causing the CPS errors. That could be what I have been fighting for the last 2 months. Strange things happen when batteries start giving odd voltages and/or current. I guess I need to run over to Costco and get a new battery after my 3:00pm call. The race track is looking promising!
MikeR
MikeR
View Public Profile
Send a private message to MikeR
Find all posts by MikeR
