Old Oct 29, 2008 | 07:19 PM
tdannar's Avatar
tdannar
Default Re: Squeaks when turning left
Is it a brake squeal? My roadster was making a squeal when turning right. I found that I use very light braking pressure to keep brake dust to a minimum. In my case, a good hard stop or two will re-seat the brake pads and stops the squeal for a while.
If this is it, you will notice the squeal will stop if you slightly depress the brake pedal while making your turn.
Hope that is all it is...
