Originally Posted by srt-6novice
when you change out the springs and struts should you insatll a camber kit when running 19 on the ack and 18 on the front.
I done the camber kits on front & back when I installed the Eibach Pro kit. Here is the post I started back when I done it. Post #39 is the most discriptive of how things turned out. Hope it helps, I'm the only one that done the camber kits that I know of.
https://www.crossfireforum.org/forum...ad.php?t=16136
