Thread: Upgraded IC?
Old Oct 30, 2008 | 03:43 AM
  #44 (permalink)
mrphotoman's Avatar
mrphotoman
Default Re: Upgraded IC?
Originally Posted by ProjectMayhem
Ok i have noticed this many many times over the past few months. The heat exchanger that is in front of the car and the intercooler under the supercharger are two different units. Will poeple stop confusing the heat exchanger with the intercooler?
L.E.T. makes a bigger heat exchanger not intercooler, Waldigs massive radiator under his bumper is a heat exchanger, the only person that has even mentioned building an upgraded intercooler was Code3. I hope this clears up some of the confusion.
If someone could make a blow up diagram of where the two units are located to put words into pictures that would be great .
I do not see anyone in this thread confusing an intercooler for a heat exchanger. Where did you see that?
You guys can spend a few thousand dollars upgrading your IC, HE and so on with minimal results or you can spend $200 to $500 and see big results. I know which route I am going.
