Originally Posted by mrphotoman
I will look up the link to the alcohol injection forum, you would not believe the detailed info over there. I have some before and after dyno runs on my old supercharged car if I can find them I will show you as well. You can also run a mix of 80% methanol and 20% nitromethane (I have 2 gallons at the house waiting on the srt6
) and you will pick up another 20whp or so with that when at the track. I have mine custom mixed instead of purchasing the pre-mixed which is about 200% more expensive. A base kit is very simple to install and the kits with the progressive controllers that tie into your MAP sensor are a little more involved but work better for partial throttle response. I have never installed a progressive controller but there is not a lot to it from what I have read up on them. I am ordering mine sometime this week, I may do the progressive controller kit but I am not sure yet. I do plan to run a small 3gph nozzle and run more water than meth since I plan to use it mainly for cooling. The more water you run the cooler the temps and the less it alters your a/f ratio and visa versa for more meth and less water. It just depends on what you want to do. I plan to run 70% water/30% meth. When at the track I am going to run the methanol/nitromethane mix.
Here are some advantages:
Lower air temperatures by 50-200+ degrees
Reduces cylinder temperatures by 200+ degrees
Increase your 87-93 pump gas by 15-20+ points
Increase horsepower safely by 10-15%
Allows you to safely run more boost and timing
Cools and protects the tops of your pistons
Longer more stable combustion expansion and progression
Removes carbon build up from combustion chambers, pistons and valves
Reduces & helps eliminate damaging engine detonation & pre-ignition
No need for expensive racing fuel or additives
Thanks. I think ECU-Adaption will be needed and from what I heard, you have to be careful to adjust the water/alcohol injection very accurate, control water/alcohol level in your tank etc... Some people had engine-problems with such a setup... Maybe it is more for the "hardcore" dragracer than the daily driver. If it is installed correctly, it sure gives more power...
